- Using SharePoint for Cloud storage
If your organization uses Microsoft SharePoint and OneDrive for internal cloud storage solutions you can easily incorporate that into an OpenCities Map workflow using these steps:
1. Open the SharePoint site in a web browser
2. Select the Add shortcut to OneDrive option
3. Use the OpenCities Map Save as... option and browse to the folder in the OneDrive list
