Posted October 30, 2019
Following is an overview of new or recently revised Bentley Map Mobile functionality.
Reference | Platform | Summary Description |
1062071 | All Platforms | Resolved an issue where attempting to open a form instance after uploading .markupdb file to Project Share would cause the map view to close. |
Posted September 18, 2019
1056001 | All Platforms | Resolved an issue where the geographic coordinate system was incorrect for some files, causing GPS location and streaming background map display issues. |
Posted September 4, 2019
964793 | All Platforms | Added ability to allow optional download of .markupdb files from ProjectWise and ProjectWise Share locations. |
1004511 | All Platforms | Added ability to support search, sort, filter and display of embedded linked files. |
1006106 | iOS | Using "Files" app, added ability to allow attachment of any file type to redline layers and elements. |
1007920 | All Platforms | Resolved an issue where use of "Back to previous screen" button after placing "Repair String" redline favorite would fail to save elements. |
1008478 | All Platforms | Removed the "Layers > Background" setting when no geographic coordinate system is present. |
1008484 | All Platforms | Enhanced "Place Duct" redline placement to support more than 2 input points. |
1009305 | All Platforms | Resolved an issue where background map layer for 'Midnight' was not loading. |
1010954 | Windows | Added "Locate Feature" tool-tip on "Feature Information" tab. |
1010957 | Windows | Added "Linked Files" tool-tip on "Feature Information" tab. |
1010971 | All Platforms | Added new "Settings > Display > Show Linked File Thumbnails" option. |
1011022 | All Platforms | In redlining, added "Search" tab. |
1011391 | All Platforms | Added optional "ForceOpenScreen" parameter to createRedline action in URI parser. |
1011691 | All Platforms | Resolved an issue in redlining where zooming in too far before "Place Note" command would result in unexpected line spacing. |
1012530 | All Platforms | Resolved an issue where intermittent disappearance of "Repair String" end caps would occur after placement. |
1012583 | All Platforms | Added optional display thumbnails of embedded linked files. |
1012957 | All Platforms | Added saving of "createRedline" URI parameters with redline layer. |
1012962 | All Platforms | Resolved an issue on the redline layer information tab, where after successful upload the "Last Shared" date value was not immediately updated. |
1013293 | All Platforms | Resolved an issue where some redline elements would disappear during "Auto-Upload" process. |
1013331 | All Platforms | Resolved an issue where an intermittent crash could occur during redline layer "Auto-Upload" process. |
1013355 | All Platforms | Resolved an issue during placement of redline linestrings where symbology could unexpectedly change when next "Redline Favorite" was selected. |
1013918 | All Platforms | Added ability to recognize "Single Finger Long Press" touch gesture in map view to complete redline linestring placement. |
1018654 | All Platforms | Resolved an issue where after downloading and applying changesets, updated view thumbnails were missing. |
1018821 | All Platforms | Removed the "Layers > Background" setting for 3D models. |
1019872 | All Platforms | Added new "Redlines / Show Action Buttons" setting to optionally display "Complete", "Cancel" and "Undo Last Point" buttons during line string placement. |
1020224 | All Platforms | Added ability to apply fixed scaling of redline symbols, dimensions and text boxes regardless of view zoom level. |
1021242 | Windows | Resolved an issue where when using a checked-out license and disconnected from internet, only demo mode was available. |
1021597 | All Platforms | Resolved an issue in redlining where selecting new symbol or symbol size for rotated symbols would reset rotation to 0 degrees. |
1021821 | Windows | Added tool-tips to all redline placement tools. |
1022336 | All Platforms | Resolved an issue in redlining where when placing symbols, the "Small", "Medium", "Large" and "1:1" size settings would have no effect. |
1023673 | All Platforms | Resvoled an issue in redlining where during "Text Callout" placement, the dynamics would show incorrect arrow and text sizes. |
1023675 | All Platforms | Resolved an issue in redlining where when editing a "Text Callout" created from a "Redline Favorites" configuration, the expected line weight control was not selected. |
1023677 | All Platforms | Resolved an issue in redlining where when editing "Shape" settings for "Text Callout" elements, the line weight control could become clipped. |
1023680 | All Platforms | In redlining, added edit handle to "Text Callout" leader line arrow position. |
1023933 | All Platforms | Resolved an issue where after initial opening of .markupdb file, expected clusters of embedded media thumbnails were not displayed. |
1023939 | All Platforms | Resolved an issue in redlining where edits of media attachment filenames were sometimes applied to the wrong media attachment. |
1023942 | All Platforms | Resolved an issue where after editing media attachment filenames, search results for media attachments were incorrect. |
1023964 | All Platforms | Resolved an issue in redlining where when editing media attachments, the filename could be deleted. |
1024223 | All Platforms | Resolved an issue in redlining where when placing annotation or callout text in a rotated view, an unexpected rotation could occur. |
1024910 | All Platforms | Resolved an issue where opening a file while changesets were being downloaded could result in unexpected behavior. |
1025382 | All Platforms | Resolved an issue where use of encoded strings containing single quotes in URI scheme parameters failed to display expected values. |
1026298 | All Platforms | Resolved an issue where Search results could include files types which have been disabled in "Layers > Linked Files" settings. |
1026570 | All Platforms | Added ability to check for and download available changesets from CONNECT ProjectWise Share folders. |
1026900 | All Platforms | Added ability for redline dimension text size, line spacing and arrows sizes to be computed based on line length. |
1027006 | All Platforms | Resolved an issue where after rotating the map view, media thumbnails could disappear. |
1028115 | All Platforms | Resolved an issue where after applying changesets, view and project thumbnails were not updated as expected. |
1029128 | All Platforms | Resolved an issue where during redline symbol placement, view rotation was not accounted for. |
1030930 | All Platforms | Enhanced file sort setting to be persisted during session. |
1033574 | All Platforms | Updated the "East City" sample file with example "Redline Favorites" configuration. |
1038500 | All Platforms | Resolved an issue where attempting to perform automatic upload of .markupdb file to non-existent destination folder would result in an error dialog with empty message. |
1040183 | All Platforms | Removed custom line styles from "Line Style" drop-down list for "Cloud" redline elements. |
1049747 | All Platforms | Resolved an issue where the "Coordinate Readout" tool failed to report XY coordinates with expected units and values. |
Posted March 5, 2019
928315 | All Platforms | Resolved an issue where "Text Callout > Shape" options appeared clipped. |
995499 | All Platforms |
Added ability to display Microsoft® Bing™ Maps streaming background maps. |
1004503 | All Platforms | Added a new backstage menu entry which provides single-click return to folder of currently opened i-model. |
1006709 | iOS | Resolved an issue where an unexpected refresh issue occurred in the "Media Gallery" after closing images. |
Posted February 8, 2019
939082 | iOS | Resolved issue where redline element "Appearance > Thick" and "Line Style" settings were not working. |
954512 | iOS |
Added new support for the following Apple iPhone models:
989571 | All Platforms | Added new ProjectWise Field Data Management forms support. |
996396 | All Platforms | Added "Clear Web Services Cache" button in settings. |
1003334 | iOS | Added new Split View support for iPad tablets. |
Posted December 12, 2018
907687 | All Platforms | Added "Settings > Logging" options to enable and share detailed application logging. |
943260 | All Platforms |
Added "Media Gallery" to display, sort and filter media file attachments. |
943264 | All Platforms |
Added “Layers > Media” display option to show thumbnail images of media file attachments on top of map. |
943266 | Windows | Added multiple file selection capability to "Attach Media" command. |
952331 | All Platforms | Added ability to edit name and description of media attachments opened from "Media Gallery" selection. |
954486 | All Platforms | Added "Search" and "Locate" support for media file attachments. |
954488 | All Platforms | Added "Search" and "Locate" support for redline elements. |
961469 | All Platforms | Added a progress indicator during file open when attached media files and thumbnails are being extracted. |
961929 | All Platforms | Added "Settings > Miscellaneous > Display Media Thumbnails" option. |
963773 | All Platforms | Resolved issue where after redline layer creation, some elements were displayed in unexpected colors. |
967952 | All Platforms | Added a “Maximize Drawing Area for Redlines” setting. |
969941 | All Platforms | Significantly improved performance when deleting redline layers or elements with large number of media attachments. |
970493 | All Platforms | Resolved issue where attempts to open the "Search Common Properties > Manual Entry" dialog would fail if previously opened. |
Posted October 15, 2018
899175 | Windows | Added CONNECTION Client support. |
931950 | Windows | Added CONNECT Licensing support. |
943406 | All Platforms | Fixed issue where rotated views were automatically rotated back to true north. |
Posted August 15, 2018
786758 | All Platforms | Added "Redline Favorites" that provide single-tap activation and configuration for existing redline placement tools. |
786759 | All Platforms | Added "Redline Favorites" that provide single-tap activation and configuration for new redline placement tools. |
786764 | All Platforms | Added ability to place user defined symbols. |
786769 | All Platforms | Added ability to place configurable linestring. |
786770 | All Platforms | Added ability to place dimension. |
786771 | All Platforms | Added ability to place dimension with text. |
786774 | All Platforms | Added ability to place orthogonal shape. |
786775 | All Platforms | Added ability to place rotated block. |
786776 | All Platforms | Added ability to place freeform closed shape. |
786778 | All Platforms | Added ability to place duct multi-line with capped ends. |
786779 | All Platforms | Added ability to place linestring with user defined terminators. |
786782 | iOS | Added ability to open and activate a redline layer using parameters passed from other apps via URL scheme. |
786783 | All Platforms | Added ability to place note. |
786784 | All Platforms | Added ability to place annotation text. |
786785 | All Platforms | Added ability to include redline layers as part of existing level filter capabilities. |
786786 | All Platforms | Added ability to upload redline .markupdb with application defined "fixed" name and destination. |
786805 | All Platforms | Added feature information to redline elements to support view filters. |
786807 | Windows | On Windows, added "Open Markup File..." command to load and view arbitrary .markupdb files. |
787920 | All Platforms | Added support for user defined (custom) and built-in (0-7) line styles. |
804073 | All Platforms | Added optional "GPS Recording and Actual Location Difference" warning messages. |
808385 | All Platforms | Added standard selection box for linear redline elements. |
808387 | All Platforms | Added point move handles to polygon redline elements. |
819306 | All Platforms | Added "Line Style" selector on tool settings dialog. |
875850 | All Platforms | Unable to see i-models saved on CONNECT Project Share folders. |
890540 | All Platforms | During redline placement, AccuDraw compass does not rotate. |
890658 | All Platforms | Due to pending service deprecation, removed all "Personal Share" support. Added new "ProjectWise Share" support. |
893552 | Windows | For Windows desktops (without touch screen), added ability to use similar/same gestures as MicroStation CONNECT for view rotation. |
897453 | All Platforms | On Android and iOS, added "Open In..." functionality to share .markupdb files. |
899702 | All Platforms | The snap option should not be displayed when using the Cloud redline tool. |
900433 | All Platforms | Added vertex edit/move handles to rectangles and rotated rectangles. |
900435 | All Platforms | Added vertex edit/move handles to orthogonal shapes. |
900967 | All Platforms | When rotating a redline symbol, the selection rectangle should not rotate. |
902829 | All Platforms | Added "Settings" to enable and share detailed application logging when "English" language is selected. |
911422 | All Platforms | Increased "Standard" and "Custom" symbol list size from 4 to 8 rows. |
921645 | Windows | On Windows, added CONNECTION Client to installer. |
Posted December 15, 2017
658749 | Android | On specific Android devices, some graphics are missing from the display. |
699140 | All Platforms | Information displayed for currently selected redline element is not cleared when new redline placement tool is activated. |
701840 | Windows | On Windows, installer allows upgrade and uninstall processes to proceed without warning when application is open. |
706551 | Windows | On Windows, the redline text dialog does not show a keyboard for touch environments. |
706552 | Windows | On Windows, using redline text emits unnecessary and annoying dings. |
706571 | Android | On specific Android devices, redline polygons and lines drawn using "Thin" line weights do not display. |
707329 | All Platforms | Cannot rename redline title as expected with "Invalid Redline Title" dialog. |
714920 | All Platforms | During login, unexpected leading or trailing spaces in e-mail address produce odd error message. |
715022 | Android | On Android, changeset downloads cannot be cancelled and updates on remaining changes are not shown. |
719956 | All Platforms | Customer reports attempted logins fail when proxy server is used. |
723443 | Windows | On Windows, in .imodel with redlines, element selection fails after turning off map layers. |
741858 | Windows | On Windows, renaming redline layer results in a crash. |
744602 | iOS | On iOS, a crash occurs when attempting to open View 1 of i-model created from design file containing multiple map models. |
744822 | All Platforms | Unable to place any other cell symbol. Only the default gets placed. |
744824 | All Platforms | Size of the placed cell symbols are not changed. |
744863 | All Platforms | Colors selection in Symbol tool dialogue is not working when creating different shapes |
757283 | All Platforms | Request to add "Proxy Server" support. |
774181 | iOS | On iOS, request to add "Google Maps" driving directions support. |
Posted July 17, 2017
592782 | All Platforms | In "Quick Start Guide > Redlines, Markup and Media Attachments" a grammar error exists. |
653352 | All Platforms | Request to include "Polish" language translation. |
655537 | iOS | The "Expired" label is not vertically centered on thumbnail tile. |
662486 | All Platforms | Change Project > Search > "Search all projects" page is not translated |
664090 | All Platforms | Customer requests business properties containing ProjectWise URL (pw://) formatted strings to present clickable hyperlink. |
671695 | All Platforms | Some Polish characters are not visible when placing redline text annotations. |
673315 | Android | For Oval and Rectangle redline shapes, the 'Thick' button in the Appearance section is cut on the right side. |
674619 | All Platforms | For German language, the Undo and Redo text is not translated. |
680372 | iOS | Customer reports unexpected "Expiry Date" and "Incremental File Update" behavior. |
681460 | All Platforms | Request to include "French" language translation. |
695066 | iOS | On iOS, a crash occurs when attempting to open i-model created from design file containing multiple map models. |
696091 | All Platforms | Text Callout information missing translation. |
696629 | All Platforms | For various languages, the text annotation "Snap" setting label is clipped. |
697482 | All Platforms | Redline text is not localized in German and Italian languages. |
698864 | All Platforms | Customer reports loss of redline data during app crash. |
699139 | All Platforms | For certain languages, the "Redlines > Sort" dropdown list options are truncated. |
699324 | All Platforms | Redline "Symbol" label appears to be hardcoded. |
699357 | All Platforms | Attempting to rotate a previously rotated redline symbol produces unexpected results. |
702245 | All Platforms | For Spanish and Russian, the text for Redline Symbol Size is clipped. |
704003 | All Platforms | Redlines sometimes display the wrong date. |
706503 | Windows | On Windows, Bentley Map Mobile cannot run concurrently with Bentley Navigator CONNECT Edition application. |
706520 | All Platforms | Text Callout information missing translation for arrow size. |
707943 | All Platforms | Redline .markupdb files do not contain geographic coordinate system information from source i-model. |
715628 | All Platforms | In 3D i-models, closed non-filled shape elements with hole property display as filled surfaces. |
720385 | All Platforms | In redlining, element range is not updated after redline arrow manipulation. |
720796 | All Platforms | Request to preserve size of redline arrowheads during manipulation. |
723000 | All Platforms | Incorrect color values are being assigned to redline text annotations. |
Posted October 20, 2016
** The latest Bentley Map V8i (SELECTseries 4) commercial release is required to reference attach or open as read/only .imodel, .dgndb, .idgndb and .markupdb files. When you reference attach an .imodel to Bentley Map the business properties are currently available in the "Element Information" and "Item Browser" tools.
*** The latest Bentley Map Mobile Publisher commercial release is required to create Bentley Map Mobile 2D or 3D i-models from Bentley Map or MicroStation data.
Posted April 17, 2015
Following is an overview of previously released Bentley Map Mobile functionality.
*** Future Bentley Map Mobile Publisher commercial release update will be required to support some of the new Bentley Map Mobile functionalities identified above.
