Bentley Map is delivered with two separate workspaces for Bentley Map and Advanced Map Finishing. The Map Finishing tools are not integrated into Bentley Map therefore the workspaces are intended to run separately. Modifying the delivered configuration to force Map Finishing Tools to operate in a Bentley Map workspace can cause program and data errors.
