In previous versions, Bentley Map V8i could be repaired or modified via the Programs and Features dialog accessed from Windows Control Panel:
1. With CONNECT Edition products (including OpenCities Map), you need to locate and run either of these files:
2. Run or double click the setup or installation file.
3. Select Repair or Modify
4. If choosing Repair, ensure the product(s) is selected, then click Repair. NOTE: This dialog may present different items that what's shown here. This is especially true for other CONNECT Edition products.
5. If choosing Modify, the dialog for OpenCities Map may not list specific items to modify. However, for other CONNECT Edition products (such as MicroStation), this dialog may contain a variety of items to modify.
6. When done, click Finished.
