- Installing from a deployment image
When a deployment image has been created, all of the necessary installation files will be found in the folder specified during the creation process.  In the following example, the location C:/Bentley/DeploymentImages/OpenCitiesMap/ is used.
To install, run Setup_ProductNamex64_10.xx.xx.xxx.exe.  For this example, it would be Setup_OpenCitiesMapx64_10.03.00.023.exe as shown in the image above.  You can do this on the machine where the product will be installed by browsing to the deployment image location.
The product will be installed in the folders specified in the deployment image during the creation process.
