This macro has been tested on V8i and CONNECT.
communities.bentley.com/.../ChangeElevation.zip
The ChangeElevation macro has two functions:
1. Extract an elements elevation and assign it to a selected property.
2. Move elements to an elevation specified in a property.
Disclaimer - This application is supplied as-is and does not come with support. Bentley Systems Inc., and the author of this programs assume no liability for damages direct, indirect, or consequential, which may result from the use of this program. Use this application at your own risk.
