This macro runs on V8i and CONNECT Edition.
communities.bentley.com/.../TextNodeTotextFile.zip
The attached macro exports text strings, their height and width, the justification and Element ID to a text file. The text file is the name of the file and will be generated in d:\. This can be edited in the macro itself. To use this macro to export annotation:
- Place a fence around the annotation.
- Load the mvba and run the macro TextToFile
- The resulting text file will be in d:\ by default.
CAUTION: This macro drops all elements in the fence. Please use extreme care or work on a copy of your production file.
Disclaimer - This application is supplied as-is and does not come with support. Bentley Systems Inc., and the author of this programs assume no liability for damages direct, indirect, or consequential, which may result from the use of this program. Use this application at your own risk.
