- Planarize 3D Polygon (MDL)
This tool is for V8i only.
Planarize Polygon Tool
The planarize polygon tool allows Bentley Map users to planarize a polygon collection feature to make it coplanar so the user can have an area and perimeter to work with.
This tool is offered as an example of what can be done with the Bentley Map API and comes without any guarantee or support.
Polygon collection before:
Polygon collection after:
Note : This tool requires XFM data contained in a 3D design file and does not work with 2D features.
   Planarize Polygon - Help Document.pdf
  PlanarizePolygon.zip
Disclaimer - This application is supplied as-is and does not come with support. Bentley Systems Inc., and the author of this programs assume no liability for damages direct, indirect, or consequential, which may result from the use of this program. Use this application at your own risk.
