This tool will perform the following functions:
1. Take an XML data schema exported from Esri and create a OpenCities Map XML schema
2. Take any OpenCities Map XML schema and apply an A/E/C CAD Symbology spreadsheet.
And, symbology can be applied to any OpenCities Map XML schema.
Details
The Bentley Symbology Integrator was originally designed to load the SDSFIE ESRI Geodatabase XML downloaded from http://www.sdsfieonline.org/ and create a OpenCities Map XML schema. The tool will also take the OpenCities Map schema file and apply a mapping spreadsheet with A/E/C CAD Symbology to the OpenCities Map Schema (see included sample: BentleyMap-SDSFIE-AEC - Symbology Mapping.xlsx). This results in a fully complaint SDSFIE (data) and A/E/C Cad (symbology) OpenCities Map environment which allows the user to work in an unified engineering / geospatial environment and optimize the data sharing process between civil/engineering design and the owner/operator community.
The tool can be downloaded from the Attachments section on this page.
Disclaimer - This application is supplied as-is and does not come with support. Bentley Systems Inc., and the author of this programs assume no liability for damages direct, indirect, or consequential, which may result from the use of this program. Use this application at your own risk.
