The limitations of Esri File Geodatabase support is as follows
- Subtypes are registered as a single feature with a domain containing the subtype values. Property based symbology rules can be used to differentiate the subtypes.
- Feature data sets are registered as separate features.
- Domains are supported only as coded value domains.
- Relationships that can be modeled as sub features are supported. However, support is read-only. Features involved in relationships cannot be created, updated, deleted, or exported.
- Annotation sub features are not supported in the Esri file geodatabase due to limitations of the API.
