| | Applies To | | |
| | Product(s): | Bentley Map, MicroStation, Power Products | |
| | Version(s): | V08.11.07+ | |
| | Environment: | N/A | |
| | Area: | N/A | |
| | Subarea: | N/A | |
| | Original Author: | Jim McCoy, Bentley Technical Support Group | |
U.S. Coordinate Systems
Click on the link below to download the document containing information on how to assess and solve geospatial coordinate system problems in MicroStation V8i & Bentley Map V8i for design files, ESRI shape files, raster images, Google Earth KML/KMZ files, and geospatial databases.
U.S. Coordinate Systems in MicroStation V8i and Bentley Map V8i
Topics Included
- What is a Coordinate System in MicroStation
- US Survey Feet vs. International Feet
- Linear Measurement Units in MicroStation
- Units for External Sources of Data
- Units for ESRI Shape Files
- Coordinate Systems for Raster Images
- Units for Raster Files with Sister/World Files
- Using Bentley Map to Import 3D Contours from Shape Files with Mixed Units
- How to Assign a Coordinate System
- Determining an Unknown Coordinate System
- Testing the Selected Coordinate System using Google Earth
- Geographic Coordinate Readout and Input in a Projected Coordinate System
- Capturing Google Earth Images in a 3D Design File
- Coordinate Systems for Geospatial Databases
- Coordinate System Considerations in an Oracle Spatial Database
- Coordinate System Considerations in Microsoft SQL Server
External Links
Bentley LEARN Server
Comments or Corrections?
