Unable to attach MrSID Generation 4 images in MicroStation
 Product(s):MicroStation
 Version(s):08.11.09.459
 Environment:N\A
 Area:Raster
 Subarea:N\A
I am unable to attach MrSID Generation 4 images in MicroStation.
Bug #25157 has been filed for the problem and the fix is planned for a future release of MicroStation.
(NOTE:  MrSID Generation 4 images can be attached in MicroStation Connect Release)
To determine the version of your MrSID image you can go to the attached website and follow the steps.
http://beingcivil.typepad.com/my_weblog/2013/01/how-to-identify-a-4th-generation-mrsid.html
1.      Launch the program GeoViewer (a free download from www.lizardtech.com).
2.      Go to File > Add Layer > Local Layer to bring in the image.
3.      Once the image appears, go to Layer > View Layer Metadata.
4.      Look under "Image properties". In the value for Format, a generation 4 MrSID will show MRSID/MG4RASTER.
The attached website tells how to convert MrSID Generation 4 images.
http://www.lizardtech.com/support/knowledge-base-article/decoding-a-mrsid-file-to-other-formats/
3.      Tools > Export > Export Map
http://communities.bentley.com/products/microstation/f/273/p/93394/270257#270257
http://communities.bentley.com/products/microstation/f/273/p/93394/270194#270194
http://communities.bentley.com/products/microstation/f/273/p/96467/282042#282042
http://communities.bentley.com/products/microstation/f/19565/p/64073/180316#180316
 Original Author:Frank McAllister
