Applies To | |||
Product(s): | MicroStation | ||
Version(s): | 08.11.07.443 | ||
Environment: | N/A | ||
Area: | Raster | ||
Subarea: | |||
Original Author: | Frank McAllister, Bentley Technical Support Group | ||
Using an Environment Variable so when attaching a raster image it will not matter if a different share drive letter is used when the DGN file with a raster image attached is opened by another user.
When attaching a raster image an Environment Variable will be used as the folder path, which will show the UNC path instead of the folder path.
1.) Define Environment Variable in Workspace > Configuration
2.) Raster Manager > File > Attach
3.) Attach Raster Reference
4.) Select raster image
If MicroStation and Descartes are used or if custom userspaces are used then the Environment Variable must be defined in both MicroStation and Descartes and all custom userspaces that are used. The Environment Variable will only be valid in the userspaces that the Environment Variable was defined.
