Eliminating The AE Table Error When Creating An Active Entity [TN]
  Product(s): MicroStation, MicroStation GeoGraphics, MicroStation GeoOutlook
  Version(s): All
  Environment:  N/A
  Area:  N/A
  Subarea:  N/A
This TechNote will explain how to eliminate the "Unable to load AE table" error when attempting to create an active entity in MicroStation when connected to a database. There can be various causes for this error when trying to build the Active Entity. Here are things to try that can help you resolve the error.
Product TechNotes and FAQs
External Links
Bentley Technical Support Knowledge Base
Comments or Corrections?
Bentley's Technical Support Group requests that you please confine any comments you have on this article to the "Comments or Corrections?" section. THANK YOU!
