| Version(s): | 95, SE, GeoGraphics | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
MicroStation 95/MicroStation SE will terminate when reconnecting to an Access database via ODBC in Windows NT 4.0
Microsoft has an update which corrects a problem that occurs when repeated disconnects/reconnects are done to an Access database in Windows NT 4.0 from within MicroStation.
Go to Article ID: Q151186 in the Microsoft knowledge base: http://support.microsoft.com/support/kb/articles/Q151/1/86.asp (Note: you may be required to register with Microsoft before accessing this document).
After downloading MSJTWNG.EXE from the Microsoft Web site, run the executable. The file "MSJT3032.DLL" (and 2 others) will be unzipped. Replace your copy of MSJT3032.DLL with this new one (version 3.000.3213 or higher) in the SYSTEM32 directory of your windows installation directory (<YOURDRIVE>\WINDOWS\SYSTEM32). See the README file included with MSJT3032.DLL for more information.
Note: The version of MSJT3032.DLL that will be replaced is 3.000.2809 or lower.
You can determine the version number of the DLL by selecting the file in File Manager or Explorer and selecting File>Properties.
Bentley Technical Support Knowledge Base
Bentley's Technical Support Group requests that you please confine any comments you have on this article to the "Comments or Corrections?" section. THANK YOU!
