| Version(s): | 10.16.00.84 | ||
| Area: | Text | ||
| Subarea: | Word Processor |
How can you control the size of subscript or superscript text or numbers? At the moment they are much too small.
With CONNECT Edition Update 16.1, the following keyboard commands were introduced to adjust the size of the subscript and superscript text. The default scale value is 0.3:
For superscript text:
TEXTDISPLAYSCALE SUPERSCALE [scale value].
For subscript text:
TEXTDISPLAYSCALE SUBSCALE [scale value].
