| Product(s): | OpenPlant PowerPID |
| Version(s): | V8i Selectseries 3+ |
| Environment: | N/A |
| Area: | N/A |
| Subarea: | N/A |
| Original Author: | Gerd Eichler, Bentley Product Advantage Group |
To insert or associate flow arrows with a pipe run it must be defined in the FLOW_ARROW_MAPPING custom attribute. For this exercise you need to have two new cells Main_Proces_Flow_Arrow and Instr_Flow_Arrow
This article covers releases for SS3 and greater. The version 01.0x will apply to all. This version number would correspond to the specific schema version 01.01, 01.02, 01.03,....
Element Template: Piping\Misc_Piping
Cell Name: Main_Proces_Flow_Arrow
Cell Library: Piping.cel
Display Label: Flow Dependent
Description: Direction depends on flow
→ Repeat the steps for INSTRUMENT_FLOW_ARROW and fill in Instr_Flow_Arrow as CellName
Select the class Pipe Run (select the Class tab if you're still on the property pane)
In the FLOW_ARROW_MAPPING custom attribute change the value for the Directional Class Name to MAIN_PROCESS_FLOW_ARROW and click the Save button.
Select the class Instrument Lines (select the Class tab if you're still on the property pane)
In the FLOW_ARROW_MAPPING custom attribute change the value for the Directional Class Name to INSTRUMENT_FLOW_ARROW and click the Save button.
Click the Save icon to save the OpenPlant_PID.01.0x.ecschema.xml schema
