| Product(s): | AutoPLANT Equipment | ||
| Version(s): | AutoPLANT XM 08.11.05.36 | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
Cannot select a new size nozzle when inserting a nozzle in AutoPLANT Equipment.
The size field whether in the nozzle insertion dialog or Component Preferences toolbar is controlled by the PIPE table in the current spec. Therefore, if a new nozzle size is created using SpecGen, ensure there is also an entry (class name: AT_PIPE) in the PIPE table with the same size.
