| Product(s): | AutoPLANT Isometrics; Auto-Iso |
| Version(s): | V8i |
| Environment: | N/A |
| Area: | N/A |
| Subarea: | N/A |
Dimension style settings can be specified in the ISOTMPL.DWG file in the project. However, some of these settings such as units and precision are ignored when running Auto-Iso.
Some settings are stored locally. These can be changed in Project Administrator.
Some of these values are also defined in the Project Administrator Help file.
