| Product(s): | AutoPLANT P&ID | ||
| Version(s): | All | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
Bentley AutoPLANT P&ID enables you to create intelligent Piping and Instrument Diagrams, Process Flow Diagrams and other Piping Schematics. P&ID provides multi-user access to nongraphical intelligence stored in XBase, Oracle or other popular database formats. P&ID is an ideal tool for engineering companies or plant operators to capture process information for system design, OSHA 1910 compliance, HAZOP studies, and maintenance management.
Note: P&ID is a powerful addition to AutoDesk's popular AutoCAD drafting package, and is fully compatible with AutoCAD 2006 and 2004, Windows 2000, or Windows XP environments,ONLY!
Note: At this time, P&ID does not support AutoCAD multiple document interface (MDI).
