| Product(s): | AutoPLANT Piping, Equipment, Isometrics |
| Version(s): | AutoPLANT V8i 08.11.05.36 |
| Environment: | N/A |
| Area: | N/A |
| Subarea: | N/A |
| Original Author: | Derek Cornell, Bentley Technical Support Group |
In certain network settings, the MDB spec file is locked when a user is in AutoPLANT Piping. This prevents other users from accessing the spec from the Component Preferences toolbar. This is a technote showing what settings to change.
The first thing that you need to do when intending to use a Microsoft Access database in a shared environment is to put it in shared mode. This can be done by using the following steps:
This will then open all databases in shared mode by default. This means that you don't have to go through this exercise every time you create/open a new database.
Note: The dialog looks a little different in MS Access 2007 but the option is still there in the advanced tab. Make sure this is checked on each workstation.
Product TechNotes and FAQs Plant TechNotes And FAQs
Bentley Technical Support KnowledgeBase Bentley LEARN Server
