| Product(s): | AutoPLANT Isometrics |
| Version(s): | V8i |
| Environment: | N/A |
| Area: | N/A |
| Subarea: | N/A |
While the information is also available in the Class Editor and Isometrics Help files, there is no continuity. This is a step by step instruction to create and use a new custom symbol in AutoPLANT Isometrics.
How do I create a new custom miscellaneous symbol in AutoPLANT Isometrics?
- Go to the following desktop menupick: Start > All Programs > Bentley > Plant V8i > Tools > Class Editor.
- Open the project you are currently using.
- Go to the folder: Base Piping Module > AutoPLANT Root Piping Class > Parent Class - All Base Components > Iso Drawing Symbols.
- Right click on Iso Drawing Symbols and go to "Insert a new component".
- Name the component Iso_Room (as an example of a symbol name).
- In the Iso_Room dialog that comes up, add the following values in a new row:
Member Name: ISO_SYMBOL
Member Value: %APP_DIR%\symbols\ROOM
Owner: Iso_Room - Now find the line Method Key: AT_ISO_BASE_SYMBOLS and click on the browse button next to it.
- Change the value to AT_ISO_GROUND.
- Save and close the Class Editor.
- Now copy the following file from:
..\program files\bentley\plant v8i\modules\base\miscsym.ini
to
..\project name\config\modules\base\miscsym.ini - Open the file in notepad and append the following section:
[Iso_Room]
ClassName = ISO_ROOM
Description = Room Symbol - Save and close the file.
- Now go to the following directory:
..\project name\config\mdoules\base\iso\symbols\
Note: You will have to create the sub folders "iso" and "symbols" since they don't yet exist. - Create three drawings:
ROOM00.dwg
ROOM06.dwg
ROOM12.dwg
These drawings correspond to the three orientation planes in Isometrics.
Note: See the following dwg files as examples: ..\program files\bentley\plant v8i\modules\base\iso\symbols\ - Now shut down AutoPLANT if it was running, and restart AutoPLANT Isometrics.
- Go to the menu pick: Isometrics > Misc. Symbols...
- Select the new symbol: Room Symbol.
Product TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
