| | Applies To | | |
| | Product(s): | AutoPLANT Isogen | |
| | Version(s): | V8i 08.11.05.36 | |
| | Environment: | N/A | |
| | Area: | N/A | |
| | Subarea: | N/A | |
| | Original Author: | Bentley Technical Support Group | |
This is an explanation and steps on how to suppress certain dimensional data when the model is not strictly oriented N-S-E-W.
Problem Description
- Open the Project Administrator.
- Go to ..\project name\Isogen\Input Options
- Select the Edit button next to the path for Options File.
- Go to Option Switch 115 which is under the "System" tab.
- The value can be set anywhere between 0-999, which means that the dimensions will only be supressed when it is within 10 degrees of North, South, East or West.
Product TechNotes and FAQs
Plant TechNotes And FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
