| | Applies To | | |
| | Product(s): | AutoPLANT Piping | |
| | Version(s): | All | |
| | Environment: | N/A | |
| | Area: | N/A | |
| | Subarea: | N/A | |
| | Original Author: | Bentley Technical Support Group | |
How to change or update the SORT_CODE value for Topworks or Valve Operators.
To change the SORT_CODE for a topwork/valve operator that is already placed in a model:
- Open the model in question and load piping.
- Go to Piping->Setup->Component Update Preferences
- Add SORT_CODE to the “Fields To Include” column.
- Click OK.
- Go to Piping->Database Tools->Update Components.
- Select the topworks/valve operators in question.
- When the Update Component dialog pops up select the Component Properties tab.
- The SORT_CODE property will be displayed and can be changed here.
- Click OK after changing the value, save your model.
You now have updated the SORT_CODE for topworks/valve operators
To change the SORT_CODE for all future Topworks/Valve Operators:
- Check the CLASS.INI file both in the install directory and the project directory and confirm that the default SORT_CODE is set to 110 for topworks The [BASE_TOPWORKS_CLASS] in the class.ini file should have the SORT_CODE value set to 110
- Check the TOPWORKS.INI file in the Project in question It can be found here: ..\%PROJECT_ROOT%\%PROJECT_NAME%\Config\
- Check each topworks/valve operator in this file and see if any have a SORT_CODE defined and change it to the proper number if it is incorrect.
- Once that is done delete the TOPWORKS.INI file that is held here: C:\Documents and Settings\All Users\Application Data\Bentley\Plant XM\Config\%PROJECT_NAME%\
- Once you save these changes and restart AutoPLANT you should notice all topworks coming in with the correct SORT_CODE value.
Product TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
