| Product(s): | AutoPLANT P&ID | ||
| Version(s): | All | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
This TechNote describes the process of modifying or adding custom fields in P&ID’s Pipe Settings dialog box. This will require modifying lisp code and a new INI file. Upon completion of the following steps all custom default values can be added to the INI fie.
Make sure everyone is out of the project and out of all Bentley AutoPLANT applications.
C:\PROGRAM FILES\BENTLEY\PLANT XM\P&ID\PIDPipeSet.ini
Contents of the file created will be the field names and your values you type in. These values will be the default until you change them. Also, this is where you can now set the default values for these values if needed.
