| | Applies To | | |
| | Product(s): | AutoPLANT P&ID | |
| | Version(s): | 8.1, 8.6, and 8.9. | |
| | Environment: | N/A | |
| | Area: | N/A | |
| | Subarea: | N/A | |
| | Original Author: | Bentley Technical Support Group | |
Modifying your process line annotation string in AutoPLANT P&ID versions 8.1, 8.6, and 8.9.
This TechNote describes the steps used to modify the annotation strings used for process lines.
The Steps
- Open your Settings Manager by typing SETT at the command prompt in P&ID.
- Go to the LINE-ID record and select the EDIT button.
- In the ITEM DESCRIPION field, verify the (linemark) is there.
- Close Settings Manager.
- Open Widows Explorer and path to C:\Documents and Settings\All Users\Application Data\Bentley\Plant XM\P&ID.
- Locate and open the PID-SUP.LSP file.
- Use Edit > Find and do a search for linemark. This should bring you to the following:
;; The function below is used with the LINE-ID settings record.
;; This value is in Item Description field.
(defun LineMark ()
(STRCAT psz "-" ltag "-" pspec )
) - You can change your desired fields in the STRCAT line above.
an example is as follows
(STRCAT psz "-" parea "-" pserv "-" pspec "-" ltag "-" pins) - All fields used in the string must also be present in the associated AT views.
- Save and Exit
Product TechNotes and FAQs
Plant TechNotes And FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
