| Product(s): | AutoPLANT P&ID | ||
| Version(s): | 08.06.xx.xx, 08.09.xx.xx | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
This Technical Bulletin describes an interim solution for circumventing a known but unresolved issue in AutoPLANT P&ID when integrated with ProjectWise in versions 8.6 and 8.9.
If when creating a P&ID through ProjectWise Explorer, the user right-clicks on the existing document and selects OPEN and is presented with the P&ID New Document dialog instead of the drawing, please use the following steps to correct the problem:
