| Product(s): | AutoPLANT Piping | ||
| Version(s): | All | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
When a Saddle is drawn in AutoPLANT Piping, a ring is placed around the main pipeline.
The ring that is shown around pipe after saddle placement is actually done on purpose. This is represents a saddle cover. This is not a requirement for all saddles. And for that reason, there is a way to prevent the application from drawing them.
The ring will not be drawn for any saddles that have a SADD_STAT value of 2. If there is no SADD_STAT field or if the SADD_STAT field is set to 0 a "saddle cover" ring will be drawn.
