| Product(s): | AutoPLANT Isogen | ||
| Version(s): | All | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
1. Load Project Administrator and drill down to the Isogen section of the project in question.
2. Under the INPUT section, hit the Edit button next to the Options Switches line.\
3. Once the Option Switches Editor is open go to page 2 of the MATERIAL LIST tab.
4. The available settings for Option Switch 2 are as follows:
SWITCH POSITION 1 - Cut Piece Numbering and Cut Piece List on/off control.
0 - Default for No Cut Piece List or Cut Piece Identification Numbers/Letters.
1 - Cut Piece List and Cut Piece Identifiers generated.
2 - Cut Piece Identifiers starting at 1 (one) or A on each isometric drawing.
SWITCH POSITION 2 - Cut Piece List Style.
0 - or blank Default for Old Style Cut Piece List.
1 - For New Style Cut Piece List.
To remove the Cut Piece Identifier and Cut Piece List from the Isogen ISO, set Switch Position 1 to 0 and leave Switch Position 2 blank.
