| Product(s): | AutoPLANT Isogen | ||
| Version(s): | All | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
Usually ..\%PROJECT_ROOT%\%PROJECT_NAME%\Config\Isogen\Final\
2. Load Project Administrator and drill down to the Isogen section of the project in Question.
3. Under the INPUT section, hit the Edit button next to the Option Switches line.
4. Once the Option Switches Editor is open go to Page 2 of the Plotted Iso Tab and Suppress the Isogen Drawing frame using Isogen Option Switch 18.
NOTE: If option switch 71 is set to SMART DWG, the title block file must be saved in R2000 DWG format. If it is set to DXF, the title block must be saved in R12 DXF format.
