| | Applies To | | |
| | Product(s): | AutoPLANT Piping XM Edition | |
| | Version(s): | 08.09.03.30, 08.09.03.72, 08.09.03.49, & 08.09.04.047 | |
| | Environment: | N/A | |
| | Area: | N/A | |
| | Subarea: | N/A | |
| | Original Author: | Bentley Technical Support Group | |
This is a complete install order for AutoPLANT Products which includes some addition software packages that can be used along side with AutoPLANT. Some of the listed software is optional, depending on which products are being used. See the notes under each software or click on the ReadMe links for more information.
Install Order and Versions
- Support AutoCAD software
- MicroStation V8 XM Edition Software Prerequisite Pack - 08.09.04.01 (ReadMe)
- Required for Bentley View and Bentley Navigator
- Bentley View XM Edition - 08.09.04.51(ReadMe)
- Viewer for Document Manager and Vision
- Bentley ProjectWise V8 XM Edition - Client Setups - 08.09.04.116
- Only needed if running ProjectWise
- For Servers, run Bentley ProjectWise V8 XM Edition - Admin Setup 08.09.04.116
- Bentley AutoPLANT P&ID XM Edition - 08.09.03.05(ReadMe)
- Bentley AutoPLANT Plant Design XM Edition - 08.09.03.30 (ReadMe)
- 3D piping package which includes Piping, Equipment, Raceways, Isometrics, & SpecGen
- Bentley Plant Framework XM Edition - 08.09.03.72 (ReadMe)
- Upgrade for 3d package, required for SP2 upgrade
- Bentley Process & Instrumentation XM Edition - 08.09.03.44 (ReadMe)
- Bentley AutoPLANT Plant Design XM Edition Service Pack 2- 08.09.03.49 (ReadMe)
- Upgrade for 3d piping package
- Bentley Plant Framework XM Edition - 08.09.04.47(ReadMe)
- Upgrade for framework for all Plant, required for ProjectWise
- Bentley Navigator XM Edition - 08.09.05.70 (ReadMe)
- ProSteel 3D R18.0 - 08.10.00.21(ReadMe)
- Optional Structural software Package
Product TechNotes and FAQs
External Links
Bentley homepage
Bentley LEARN Server
Plant TechNotes And FAQs
Comments or Corrections?
