| Product(s): | AutoPLANT Piping XM Edition |
| Version(s): | 08.09.03.XX, ,08.09.04.XXX |
| Environment: | N/A |
| Area: | N/A |
| Subarea: | N/A |
| Original Author: | Bentley Product Advantage Group |
This is a complete install order for AutoPLANT Products which includes some addition software packages that can be used along side with AutoPLANT. Some of the listed software is optional, depending on which products are being used. See the notes under each software for more information.
Install Order and Versions
- Support AutoCAD software
- MicroStation V8 XM Edition Software Prerequisite Pack
- Required for Bentley View and Bentley Navigator
- Bentley View XM Edition
- Viewer for Document Manager and Vision
- Bentley ProjectWise V8 XM Edition - Client Setups
- Only needed if running ProjectWise
- Bentley AutoPLANT P&ID XM Edition
- Bentley AutoPLANT Plant Design XM Edition
- 3D piping package which includes Piping, Equipment, Raceways, Isometrics, & SpecGen
- Bentley Plant Framework XM Edition
- Upgrade for 3d package, required for SP2 upgrade
- Bentley Process & Instrumentation XM Edition
- Bentley AutoPLANT Plant Design XM Edition Service Pack 2
- Upgrade for 3d piping package
- Upgrade for framework for all Plant, required for ProjectWise
- ProSteel 3D R18.0
- Optional Structural software Package
- Bentley Navigator XM Edition
Product TechNotes and FAQs
Comments or Corrections?
