| 868334 | ASME NB: Pressure term calculations use maximum D/t from header and branch instead of header only |
| 637020 | Buoyancy is not applied to copied segments |
| 631415 |
| 625322 |
| 620771 |
| 619540 | ASME NB: Incorrect stress results may be reported for negative face of a reducer node that is directly connected to a tee branch |
| 579963 | Tee inserted at the branch of another tee incorrectly inherits properties of the existing tee |
| 537789 | ASME NB: Stress summary containing equation 10 transient with a user defined non-reversing SAM category combination may give incorrect results |
| 522111 | Ground motion time history case with multiple .tih files reporting incorrect values |
Critical & High issues released in version
