Critical and High issues released in AutoPIPE CONNECT v.12.04
Items fixed in this version of the application
1102025Material Libraries: Incorrect data may be retrieved from the library for certain materials
1101733Expansion and modulus of elasticity values for standard material “AU-TYPE 309” are incorrectly retrieved for “B311-86” and “B311-92” material libraries at temperatures higher than 900 deg F
1101096Pressure extension forces and moments not considered for B31.3 and B31.1 2018 sustained combinations at 0 pressure
1096446ASME B31J: SIF values for Unreinforced Fabricated tee with sloped configuration may not be calculated correctly
1093263Properties for SA671-C70-22 code dependent material may not be retrieved correctly when using ASME2004, ASME2007, or ASME2009 material library
1089476
Y factor should not be considered in calculations of Hoop stress and ASD category for DNV 2012 and later editions
1087906
ASME NC/ND: Allowable case for Sh, Sy in Eq. 9 is incorrectly used for 1980+1980S add. and earlier editions
1083320
ASME B313 Material Libraries: Incorrect allowable stress, yield strength, or thermal expansion data for some materials
1062015
ASME NC/ND: B2 stress index and allowable calculations for a reducer may use incorrect pipe properties and pressure temperature data
1061807
Time History Profile (*.THP) file with time and/or load values having more than ten characters may generate incorrect Time History results
1033576Density and Poisson’s ratio may not be updated correctly when switching material library
109893Program hangs after copy/paste of a tee
Critical issues released in version
