Q. How to Load a Material Database into AutoPIPE Vessel?
1. Select Execute > Manage Material Database to display the Material Database Manager.
2. Select File > Open to display the Open dialog.
3. Navigate to the appropriate database file (.emdm), then press Open.
How to add a new material into AutoPIPE Vessel
1. Version 42 and higher
2. Version 41 and lower
How to Set the Default Material Database
Support Solutions and FAQ's
Bentley AutoPIPE Vessel
Bentley Select Services Technical Support webpage:
