| Product(s): | eB Web | ||
| Version(s): | 15.x.x, 16.X.X | ||
| Area: | Reports | ||
| Subarea: | Authentication | ||
| Original Author: | Aakanksha Gupta, Bentley Technical Support Group | ||
"An error has occurred during report processing. (rsProcessingAborted).Cannot create a connection to data source 'XYZ_Datasource'.(rsErrorOpeningConnection) For more information about this error navigate to the report server on the local server machine, or enable remote errors"
This can be done to restrict the accesibility to the report. Particular user are given direct permission to access the report through windows authentications. Try to login with the valid domain name and windows credentials, as permissions to view reports can be restrictive to windows authentication.
This can be provided by making entry in the security tab for the desired user.
