To approve the template made from “from existing”
 Product(s):eB Director
 Version(s):15.5, 16.X.X
 Environment: N/A
 Area: N/A
 Subarea: N/A
 Original Author:Aakanksha Gupta, Bentley Technical Support Group
Background:
Create a template from "from existing" option provided on the templte option.
Workaround:
Please follow the following steps, for the work around:
1)     Log on to eb Director
2)     File > new >from Template
 3)     Classes> work order>IDC>IDC-01T>create
4)     Work order1 is created > change the class of the WO i.e from IDC to CTREV( or any )> save it > refresh>
5)     Make a copy
6)      The copy of WO ie WO2 is opened> change the class to IDC> save it >refresh
 7)      System admin> classes> work order> IDC> from existing > drag and drop the copied work order i.e WO2 > finish
8)      Change the class of the work order (ie WO2) temporary to CTREV for eg.> save and refresh.
 10)   Go to the template created >approve it > save it.
Hope it will work for you.
