| Product(s): | AutoPLANT Isogen; Project Administrator |
| Version(s): | All |
| Environment: | N/A |
| Area: | N/A |
| Subarea: | N/A |
| Original Author: | Derek Cornell, Bentley Technical Support Group |
This technote demonstrates how to make XCHG SYSPREF files (PXF, PCF, Isogen) projects specific.
- Copy the following directory (and all files/subfolders) to your project directory:
from ..\program files\bentley\plant v8i\xchg\
to ..\<project name>\config\xchg\ - Now open the file ..\<project name\config\xchg\SYSPREF.INI file in notepad.
- Go to the [PCF] section and change all the aliases from %Network_root% to %Project_Root%.
Note: If PXF or JSM or regularly used, do the same for those sections as well. - Start Project Administrator.
- Go to ..\<project name>\Import-Export\Main.
- Change the path to the SYSPREF.INI file so that it is read from the project.
- Restart AutoPLANT in order for Isogen to recognize the updated settings.
Product TechNotes and FAQs
Plant TechNotes And FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
