OPPID - SS4 What is New
V08.11.09
What’s New?
The Bentley OpenPlant PowerPID V8i (SELECTseries 4) release is the latest release of our newest Intelligent P&ID Solution.  OpenPlant PowerPID is an Open and interoperable P&ID product based on ISO 15926 that allows any application using the open schema to natively share data.
OpenPlant PowerPID is a productive and easy to use application for production of P&IDs allowing users to capture and reuse information in an open format.  It reduces the time required for design and documentation of facilities and captures process information for system design, plant studies and HAZOP studies across the lifecycle of the asset.
Key Features of Bentley OpenPlant PowerPID V8i (SELECTseries 4)
New Features of Bentley OpenPlant PowerPID V8i (SELECTseries 4)
SS3 Support:
