OPPID Tag Duplication
Product(s):OpenPlant Modeler
Version(s):08.11.09.XXX (SS5) | 08.11.11.XXX (SS6)
Environment: Windows 7/8.1/10 (64 bit)
Area:
Subarea:
Original Author:Bentley Product Advantage Group
The current setup of OpenPlant Power P&ID does not allow for tag duplication.
Case 1
Defining a tag in OPPID
  1. Open DGN in OPPID application
  2. Place instrument and tag (A-AE-0001)
  3. Place instrument and try and create duplicate tag (A-AE-0001)
  4. Duplicates are not allowed
Defining a tag in Data Manager first.
  1. Open Data Manager
  2. Create instrument  A-FT-0001
  3. Open DGN in OPPID application
  4. Place instrument
  5. In Tag Dialog Browse and select tag (A-FT-0001)
 To allow Tag Duplication:
Change the BMF_REQUIRES_UNIQUE_BUSINESSKEYS variable value below to 0 in proects *pcf file.
BMF_REQUIRES_UNIQUE_BUSINESSKEYS = 0
Case 2
To have duplicate tags for different class types, the Requires Unique BusinessKey custom attribute can be used.
Current workflow
  1. Place Discreet instrument: A-FT-0001
  2. Place Orifice (inline flow element): A-FT-0001
  3. Duplicate tag appears
  4. Cancel Orifice
To allow Duplicate tags of different class types
  1. Open OpenPLANT_Supplemental_Tagging schema
  2. Add Requires Unique BusinessKey custom attribute to required class
  3. Make sure BMF_REQUIRES_UNIQUE_BUSINESSKEYS variable value is 0 in projects *.pcf file
  4. Place Orifice (inline flow element): A-FT-0001
  5. No Duplicate occurs
Comments or Corrections?
Bentley's Product Advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
