Does AutoPLANT P&ID SelectSeries 3 support Windows XP 64 bit?
The AutoPLANT Suite does not support Windows XP in a 64 bit Environment.  If you wish to proceed in a Windows 64 bit Environment you must use Windows 7 64 bit along with the AutoPLANT P&ID SS4 64 bit version.  Please refer to the readme for all supported OS versions.
