| Product(s): | eB Web | ||
| Version(s): | 15.03.02.261, 16.x.x | ||
| Area: | Documents | ||
| Subarea: | N/A | ||
Is there a limit to file sizes I can upload in the web UI?
In versions up to and including 15.3.2, the size of the file is limited to 32-bit file sizes (max about 3.96Gb) There is a later change in v15.4.1 that allows it to upload 64-bit file sizes (up to Exabytes) so until 15.4.1 is released, you should not expect to be able to upload 4 or 5 Gb files.
