| Product(s): | eB Web | ||
| Version(s): | 15.03.02.261 | ||
| Area: | File | ||
| Subarea: | N/A | ||
In the Web UI, I attempt to checkout an Excel file, and it fails. The error states:
I'm sorry, there was a problem downloading the file",an error occurred during the transfer. Server Message:'Could not lock the file 'c:\eBCheckout\' (Some of the requireed values were not specified. Cannot insert the value NULL into column 'machine_name',table 'eBProd.dbo.checkout_files';column does not allow nulls. INSERT fails.
This issue relates to http://support.microsoft.com/kb/323308
In short: IE does not allow you to download Excel files via SSL if the server specifies a no caching header. The web server specifies no caching because otherwise IE won’t always fetch the right file. This is a bug in IE. After following the instruction in the KB article, the checkout now works as expected.
Internet Explorer 7 and Internet Explorer 8
To resolve this issue in Internet Explorer 7 and in Internet Explorer 8, follow these steps:
1. Start Registry Editor.
2. For a per-computer setting, locate the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings
3. On the Edit menu, click Add Value.
4. To override the directive for HTTPS connections, add the following registry value:
"BypassSSLNoCacheCheck"=Dword:00000001
To override the directive for HTTP connections, add the following registry value:
"BypassHTTPNoCacheCheck"=Dword:00000001
5. Quit Registry Editor.
