If the following was displayed in the application bar:
than AutoPIPE has determined that no valid license is available or has yet to be specified.
AutoPIPE will run in Demo mode with limited functionality :
Cannot insert more than 20 points in the model.
Cannot run any analyses if the model has more than 20 points.
Note: In Demo mode any file can be imported into AutoPIPE but a valid license is required to export or Save a model file.
The first step in the trouble shooting why the program reverted to demo mode starts by checking the Licenses Available and License Status in LMT (License Management Tool).
Note:
Interactive Guide to Licensing
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
