Applies To | |||
Product(s): | eB CADConnect | ||
Version(s): | 15.04.01.325, 16.x.x | ||
Environment: | N/A | ||
Area: | Configuration | ||
Subarea: | |||
Original Author: | Deepti Patil, Bentley Technical Support Group | ||
In the CAD-Connect browser, while viewing a Document, if you click “Get Local Copy” from the Task
Pane the wizard will open with an error. If you unselect Modeless browser in the CAD-Connect Configuration you do not receive this error
Check if this Internet options are enabled.
Internet Options >Advanced tab Settings
