05. License Management Tool (LMT) issues with AutoPIPE v.11.04 or lower:
Note: Who is my Bentley on-site Administrator?
  1. How to Start LMT
    1. Using AutoPIPE 9.6.2.6 and Higher:
      Start AutoPIPE, select File> License Management Tool
    2. Using AutoPIPE 9.6.1.11 and lower
      Start AutoPIPE> select Tools> Settings> License Management Tool
    3. OR navigate to LMT installation folder: C:\ Program Files (x86)\ Common Files\ Bentley Shared\ LMT\ LicenseTool.exe
  2. License Management Tool - Overview
  3. License Management Tool> Activation Status TAB
    1. Product Activation Modes of Behavior (i.e. Trial, Activated, Offline, Disabled, Expired, Checked Out)
    2. DISCONNECTED MODE EXPLAINED [FAQ]
    3. Batch file to remove invalid activation status entries - Asian characters
    4. "The Server succeeded but doesn't have a license for this product" message
    5. AutoPIPE Nozzle license status = Expired on the Activation Status tab, why?
    6. Why is my application repeatedly deactivating?
               i. User's computer not registered
               ii. Bentley Onsite admin to run Connected User Report
  4. License Management Tool> License Checkout TAB
    1. Software does not show in the bottom window
  5. AutoPIPE, Ram, and STAAD product ACTIVATION screen appears when I open the  program or Appear to be stuck in Trial mode even if the license is available?
  6. Issues related to Connecting to the SELECTServer:
    1. Troubleshooting Product Activation for XM and Higher
    2. Trace License Request from AutoPIPE to Hosted Server
    3. How do I configure Bentley products to use a proxy server?
    4. "The client does not have access to this site"..+
  7. "Site Activation Key has Expired" message in LMT for AutoPIPE
  8. How to Request an updated license for a Deployed Select Server
  9. How to find your "Select Server" and "Site activation Key" information
  10. How to fix License Management Tool shortcut after installing AutoPIPE?
  11. If I have a proxy server where do I enter the server name, user name, and password in the CONNECTION client?
  12. Validation of the response file has failed. Error No.: -10504
  13. Will updating LMT help with 10 min or less overusage issues?
Licensing - AutoPIPE
