| Version(s): | 08.11.09.459 | ||
| Area: | Graphics Display | ||
| Subarea: | Display Styles |
Issues with Transparent: Shadows on the Display Style list
I want to generate shadows using Display Style "Transparent - Shadows" but no shadows are found. What can I do?
By default, the setting is set to "30" for "Transparency Threshold" under the category Render Mode for Transparent: Shadows.
Other Language Sources
| Original Author: | Judy Wong |
