01. Interactive Guide to Licensing AutoPIPE v.11.04 or lower
NOTE:
1. This procedure assumes that AutoPIPE has been installed correctly along with any dependencies.
2.  If using AutoPIPE V8i 08.09.xx.xx to 09.05.01.05, be sure that Bentley IEG has been installed..
Step #1: Start AutoPIPE 11.04 or lower:
Start AutoPIPE by using one of the following Techniques:
a. Using the Menu - get to a Windows Start button,
i. Win 7 : Select  Start button> All Programs> Bentley Engineering> AutoPIPE....
b. Select the Desktop Icon:
       OR            OR
This will open the application group, now select the program itself from the group listing, shown below:
Licensing - AutoPIPE
