This document will cover the process of using an existing Associated Item (In this case SERVICE) to use a specific MicroStation template from a DGNLib file. This will allow the user to select SERVICE and set the value as desired and have the piece of equipment adopt a specific template that controls color, line weight and linestyle of that equipment. It will also allow this value to automatically be passed to related nozzles so they adopt the same template. Additionally if the user changes the value for SERVICE the equipment and related nozzles will update accordingly. This will only work with an ASSOCIATED PROPERTY and not a standard common property such as Description.
Select link to download or open document communities.bentley.com/.../0508.How-To-Add-Service-Key_2D00_in.pdf
Regards,
Tony DeRosa
Bentley Plant
