| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Import |
| Date Logged & Current Version | July. 2017 11.00.00.22 |
SACS 11.0 : transferring .pipelink file from SACS to Autopipe seems impossible, because SACS can’t open the .pipelink file (see figure below). Do you have any idea about that ?
Switch to Precede 32bit. In the SACS Executive Settings:
Insert> Model From Bentley SACS using PipeLink
